Originally Posted by
mb3000
Just thinking out loud here. The way I see it, cam gears (+1 intake, -3 exhaust) are only extending the valve overlap (stock is 33deg.) I haven't however, been able to figure out how many degrees this modification adds.
In most discussions with small turbos (TD04 for example) a large valve overlap is generally though of as counterproductive, with the exhaust blowing back into the combustion chamber. For me, this raises questions about the validity of that statement (to an extent) as we see TD04 cars achieve good results from cam gears.
If valve overlap isn't as big of a problem as we first thought, than maybe cams like the 264 profile (48 degree overlap) would be more beneficial than adding cam gears. Other cam combos like 264 intake and 272 exhaust (52 degree overlap) and 272 all around (56 degree overlap) might also be a good choice.
We all know stock heads and cams can make great power, this is just another way of thinking. Feel free to correct me if my theory or math is wrong, I just wanted to put this out there to see what y'all thought.
