Results 11 to 20 of 32
Thread: R & R 3S dash speakers?
    BAD ASS - I've got one Not Verified Feedback Score 9 (100%) j2k4's Avatar
    Quote Originally Posted by Spyder View Post
    I will be using some CDT ES-02 in the dash. If I don't like it I will give those a try.
    Boy, if you don't like the CDTs...that's some badass little drivers, there.
    JNS Engineering verified Feedback Score 1 (100%) Jimvr4's Avatar
    San Jose, CA
    Anyway, the speakers are pretty weighty, in a tiny-speaker sort of way, and I will be wary of them dropping out until they convince me they aren't going to...I may put some sort of soft shim between the mags and whatever lies beneath them in situ.
    To prevent them detaching over time maybe you could put a slight notch in the sides of the tabs of the frame and loop a thin wire across the bottom of the magnet anchoring it in the notches.
    Thought about doing something like that, Jim, but if they do come out, there's really nowhere for them to go, and not much chance of damage, so I'll wait, if, as, and when.
    In the meantime, I wouldn't mind knowing how well the RTV works, and if my read on what it took to do the job was correct.
    so these are the new 220 GTO's?
    can they be made to fit with a toilet gasket? that was WAY easier.
    Monogamous Gigolo verified Feedback Score 8 (100%) 2fnloud's Avatar
    The 220 GTO's did not look OEM, this does.
    i'll give you that. the mount looked oem though. and WAY easier to do.
    mine are currently covered by a dash-mat, so i don't think it would make a difference either way.
    Post redundant
  8. #18
    The tweeter is mounted in the flush mount cup...it should come out.
    looks like the tweeter should twist lock by looking at the three slots around the perimeter of the flush mount cup.
  9. #19
    Ah - so what I'm currently seeing as the speaker is two pieces - I'll check that shortly - thanks, Steve.
  10. #20
    yes the casing with the flange and the tweeter that is in the "cup"
