Results 1 to 4 of 4
Thread: Issues with Second gear
    3k enthusiast Not Verified
    August 2009
    My brother has been experiencing some issues with his 1995 SL manual transmission.
    He claims that the clutch pedal has little to no pressure, that it won't shift into second and reverse is difficult. 1,3,4, and 5 are working properly.
    He said that yesterday when he got out of the car, it smelled bad. it wasn't rubber, but he thinks it was the clutch.
    What could be the issue here? I won't be able to take a look until saturday, I will post some pictures and update then, in the mean time, I would really appreciate some help.
    August 2009
    I've been recommended that it's the clutch.probably going to upgrade to a stage 2.
    Banned J. Fast's Avatar
    Check the main clutch res to see if the fluid is full. If you have no fluid from a hydro line break you will get blocked out and have to start the car in gear. Fix the fluid leax and then take it for a spin up a hill and see if it slips. If you smell burning clutch or it slips, the clutch is bad. Let us know what you find out.
    August 2009
    I checked the clutch reservoir and it was full...
