Current:
2004 ML500 - Mommy Mobile
1995 3000GT VR-4 - lawn gnome
1999 3000GT SL - 7,436 miles
FOR SALE:
Hell no SOHCs dont suck, non-interference and 9:1 compression, perfect for a big single... SSM... hmm might have to check out their kit then...
Wait, you mean no more 3/S garden in the front yard?
You guys aren't recreational gardeners anymore. You're full blown farmers.
Which BTW... who has some used TT manifold hardware lying around? I need (12) manifold acorn nuts in good shape and (20) TD-05 precat/turbo flange studs/bolts and nuts. I have a turbo kit to install. Who want money?
That too. I once had a 97 base and noticed smoke from the timing belt area and the engine started to overheat. So, I kept during it to the garage. Changed the timing belt (which was mostly melted rubber) an the water pump and the car kept on trucking.
I'll have two VR-4s here soon, a 3.5L block, some cracked 360 magnum heads, and a few other items going to the scrap yard. There's not a market for some things. It is what it is.
