Results 1 to 10 of 13
Thread: Beofre launching, how do you warm up our AWD ttires?
    Pueblo, CO
    OK, so im sure everyone knows i just got my tcase and outputshaft to complete my drivetrain. Now, my question is, im using slicks, and do we with slicks and awd go thru the water box at the strip? I see some go around it and some light em up. Just wondering what the few that use slicks or DR's do?
    I know it might sound like a noobish question, but i want to be sure before i try to light em up when im not supposed to. Adam, Dave...chime in
    Frontline Fabrication verified
    Morgantown, WV
    Well going by your sig you shouldnt have a problem scuffing them up a bit to get the crud off of them, but you probably won't be able to do a full out burnout to get the tires up to temp.
    Here is an example of how we do it...this is my best friend in his 2G talon (old vid but has his burnout on it)
    Aug 2011
    Pittsburgh/Norfolk
    Quote Originally Posted by MeTarzan View Post
    you know kisner? i worked at tpg with nate for like 14 months before i left for the military
    1992 Dodge Stealth RT TT (41,968 Original Miles)
    Corn Fed
    Mods: 3.5L, TD05 14B's, 2.5" Barrel style Water/Air intercooler, 1600cc injectors, AEM EMS v2, Dual 255lph pumps, 3sx pulley
    I'll post a couple vids of our evo to show some examples. This car has gone through hundreds of track passes, and we are always testing and changing things to get the best result. The first video is from this year, on these passes we were not doing burnouts. Drove around the water box, then backed up to it, then pulled forward. The track is sticky enough it will pull most of the crap off the tires on its own. Then went to the line and went for it, these were not our best 60's but ended up being our best runs. This was on some smaller M&H slicks running 10-11 psi in the tires.
    The second video is from two years ago, on a bit less power still getting the car setup. The tires then were 26'' Hoosier QTP's, and as you can tell in the video, plenty of burnouts were done. To do the burnout you pretty much roll through the box then launch the car while the tires are wet. This will clean them off and heat them up a little, which generally should help you.
    In your situation knowing that you dont want to break anything, i would start off simple, and then figure out what will work for you. Start with the pressure around 15-16 psi, drive around the water and up to the line. You will need a higher 2 step than on street tires and you will need a bit more clutch slip. once you launch it the same thing going down the track, just keep it straight. At the other end though, get on the brakes, but make sure not to slam them, the tires have a lot of "slop" in them at low PSI, nad if you slam them it can make the rear end swing out on you, and its not fun after that.
    And the list goes on...
  5. The Following User Says Thank You to Austin@STM For This Useful Post:
  6. #5
    Pueblo, CO
    Thx Austin. Appreciate it. That is awesome experience there. I will try that. I was going to start at alot higher psi like 32 then work my way down. think thats too little at 15-16 for first time?
  7. #6
    Heres a couple examples of me as well, the first video is my first time ever on slicks. As you can see i bogged pretty bad on the launch, not slipping the clutch enough, and my 2-step was a little low. It was still fast enough to get me the boot after one pass though
    The second video is my second attempt at slicks, a little more 2-step and it was off to the races. A little bit of tire spin off the line, but all 1.4 60's that day. Like i've told you in the txt's this is all on one stock unbraced transfer case. Sure the weight helped, but it all comes down to the driving, the slicks arent going to break anything, they are actually better for your drivetrain than a regular tire, as you launch the sidewall flexes and loads up your drivetrain same thing as you are slipping the clutch, then they hook and go. Street tires have solid sidewalls, thats part of why they spin so much, they have no give so either something is breaking or the tires are gonna completely loose all traction.
    All my passes were on about 14 psi in the tires. Never did a burnout (tried it once and it didnt help me) on these passes. Just rolled around the water box and straight to the line.
  8. The Following User Says Thank You to Austin@STM For This Useful Post:
  9. #7
    I just posted two of my videos to. 15-16 is not that low, your tires will still be balloons at that pressure. So you will probably get a little spin like i was, but thats not always a bad thing. If you have the tires on your car while your driving around town i would keep them around 25 psi. These tires arent meant for high pressure like street tires are.
  10. #8
    Pueblo, CO
    ok cool. i am trailering the car to the track just incase if you know what i mean. So, i will have them starting out on the car with the low psi. My 2step is at 5600 Rpms building 15psi. Sucker sqwats hard and gets after it
  11. #9
    i prefer dousing mine with rubbing alcohol & setting them on fire.
  12. #10
    Bolton MA
    I really wouldnt suggest your first pass at less than 15-16psi. We are talking about someone going 120+ mph for the first time on slicks. It's different than street tires.
    1.4's are possible without doing a burnout..just go around the water box. It all depends on the track prep.
    Trash Can Club
