dr-31's are the wheels 18x8.5. Cant wait for the new xtd stage 4 to go in![]()
I didnt know ur supposed to slip the clutch and not dump it when using 2 step?
What is your setup?
* EDIT - Just saw your other thread and you have your setup listed.
Sweet vids man. Car looks great! Can't wait to get the 97 front on my car soon too. Your launches make me want 19t's and 2step lol
There is never a right time to dump the clutch, it will just end up like this.
Thats a T-case out of A customers evo. Dumped the clutch off 2-step with slicks on and it exlpoded. Took out the bellhousing, cracked the front diff, ans also dented the oil pan which could have taken out the motor if it hit harder.
You want to slip the clutch just enough to load the drivetrain, but not spin it to much that your just sitting there spinning the clutch and not the tires. If you still have an E-brake you can learn to use that to load it as well and really launch hard.
-Austin@STM
And the list goes on...
I love your paint job. And your rims. Mmmmmm.
Up and running!
I will preload the drivetrain then dump it. Maybe Ill start to slip it a bit now
I never dumped my clutch because I am too scared to mess my car up. But then I dont see the point to go to a track and pay them money for me to run the hell out of my car either lol.
Exactly on a RWD or FWD car you dump the clutch and it just breaks the tires loose. On an AWD car you have a LOT more grip and shocking the drivetrain will cause broken parts. Burning a clutch from slipping it too much is a lot cheaper to replace than getting a new TC and/or transmission.
