Comes with...
> Emanage Blue Main Unit
> Plug n Play Main Harness with Ignition Harness for Timing Control
- I used an AEM patch harness because the connections are epoxied and
don't bend/flex like boomslang. Better quality in my opinion. All connections are soldered and wrapped in heat shrink tubing with the exception of the red wire in the picture(Butt Splice). That wire is the EGRT input. I used it to
log my wideband. If you would like, I can reconnect it if you want to use the underhood connector or I can leave as is.
> 3 Bar Map Sensor
> "Special" comm cable to connect with the unit.
$225 Shipped
