For years I have been trying to fix the clacking noise my transmission makes whenever the clutch is released, a noise which I can now hear even when in gear, which I assume is a result of the extra sound transfer I get as a side affect of solid mounts.
Anyway, one thing I thought of the other day was the thickness of the sealer used to put the transmission back together. I rebuilt the transmission last year, pre loaded the bearings, and sealed the case back up with a black permatex type stuff. And probably used way more than I should have.
It seems to me that the thickness of the sealer could actually throw off your pre load. Is this possible? I am not convinced myself since the pre loads are usually around 5 - 10 mil, and the sealer probably can't be much more than 1 mil. Since there are 3 sealing surfaces that would be 3 mil of additional case length. So if you had your pre load as loose as possible to begin with, 5 mil, it would now be 2 mil.
