Results 1 to 8 of 8
Thread: 94 base model no heat any ideas?
    Nov 2011
    portland or
    I have no heat but temp reads fine. It has been that way since i did the heads. I think it is in the internal controls but dont know wht would go bad or where to start????
    Andover, MN
    Heater core issues most likely...
    Ether the coolant isn't reaching the heater core (hoses bypassed when you did the heads) maybe the hoses got mixed up, or the flap that changes the air route through the core isn't working. Some cars won’t get heat if the coolant is low but IDK if that could be the case on these cars, the core is pretty low.
    Is it even blowing air?
  4. The Following User Says Thank You to green-lantern For This Useful Post:
  5. #4
    94 3500gt vr2? verified
    NC
    that flap greenlantern is talking about is the blend door and i'd say is the most likely cause
    they break easily in most cars although i've never seen a broken one in a 3/s
    could also be the cable came off the blend door under the dash
    when you turn the hot/cold knob, do you hear a thump type sound? (this would indicate cable is attached and door is opening/closing)
    or do you have digital climate control?
    i think having hoses backwards could slow down flow through the heater core, but shouldn't stop it all together
    if it's bypassed, that would be too obvious, but i'm sure it's been overlooked before
    could also be a blockage in the heater core
    not fun getting that out but you can test it and clean it easily
    hit it with lightly with air compressor on the in line and make sure coolant comes out the out line
    other than that, look at what else would affect coolant flow (thermostat, water pump, etc)
  6. #5
    lol thanks, I have no idea what they call that damn thing.
  7. #6
    Ann Arbor, MI
    With the car cooled down, peer down into the radiator cap. Are you topped off? Did you get all of the air out of the system after doing your heads?
    After draining coolant, I usually run the car up to operating temp with the cap off and slowly add coolant as it needs it. Maybe someone else has a better way of getting all of the air out.
    Beyond that, check the door on your HVAC unit like people here were mentioning. Can you feel the HVAC unit (plastic box behind the radio) get hot once you are at operating temp? If you feel heat coming off of the HVAC box, and lukewarm air is coming out of the vents then likely the flapper door is not functioning.
  8. The Following User Says Thank You to Alex3000gt For This Useful Post:
  9. #7
    Nov 2011
    portland or
    thanks yes i get air i think it is flap also havent felt the box behind radio yet but deff on my to do list
  10. #8
    NC
    if it's not the blend door, look more into flushing the heater core, and again be cautious with the psi
    good reference:
    The heater core took a crap. Literally... - 3000GT/Stealth International Message Center
