Results 31 to 40 of 267
Thread: Let's talk coilovers
Threaded View
    Fowlerville, MI
    I haven't seen a general coilover thread, so let's do it. I'm looking for a thread similar to the 19T variant thread to get opinions and real world data if available. Let's keep it to 3S specific for now then maybe get into the Evo setups with the Supercar Adapters.
    links are just for example, not necessarily cheapest
    Tein:
    Flex: Tein Flex AWD - Suspension - Pampena Motorsports
    Spring Rate (F): 671lbs/in (12kgf/mm)
    Spring Rate Adj Range (R): +2.0~-2.0lbs/in (112~-112kgf/mm)
    Spring Rate (R): 336lbs/in (6kgf/mm)
    Spring Rate Adj Range (F): +4.0~-2.0lbs/in (224~-112kgf/mm)
    Benefits:EDFC, 16-Way adjustable, Spring compression/ride height separate
    Cost: Expensive (comparatively)
    Ksport
    Couple different versions:
    Kontrol Pro: KSport Kontrol Pro Damper System Coilovers - Suspension - Pampena Motorsports
    GT Pro: KSport GT Pro Damper System Coilovers - Suspension - Pampena Motorsports
    SPRING RATES:
    Front: 8.7kg
    Rear: 7.2kg
    Benefits: Cheap, 36-Way adjustable, 1-year warranty
    Cost: Leak/quality (fixed in newest revision?), QC and build variations
    Megans
    Supercar Engineering
    SPRING RATES:
    F: 62mm ID; 180mm length; 12 kg/mm (671lbs/in)
    R: 62mm ID; 200mm length; 8 kg/mm (447lbs/in)
    DAMPER SPECS:
    F: 120mm stroke; 260mm length; M2 valving code
    R: 115mm stroke; 240mm length; A1 valving code
    Benefits: Cheap, 32-way adjustable, 1-year warranty
    Cost: any?
    Ninja Performance
    http://www.ninjaperformance.com/prod...k73v4kes37jmg2
    Spring Rate: Front 670lb/in(12kg) / Rear 447lb/in(8kg)
    Cost: any?
    KW Variant 3
    Benefits: Compression/rebound seperate, Spring compression/ride height separate, 14-way adjustable
    Cost: Expensive
    BC Racing
    BR Series: http://store.pampenamotorsports.com/...-coilover.html
    RAM Series: http://store.pampenamotorsports.com/...-coilover.html
    Never heard of these until I stumbled upon them at Pampena's site
    CX Racing
    http://www.cxracing.com/mm5/merchant...gory_Code=COVR
    SPRING RATE:
    Front 12kg(670lb/in) / Rear 8kg(447lb/in)
    Benefits: Dirt cheap (seen as low as $650 new)
    Cost: Get what you pay for?
    D2
    http://www.streettunedmotorsports.co...ers_3000gt.htm
    Benefits: 32-way adjustment
    Costs: Any?
    Please link to any I missed.
