That may be a function of the sprung rate, or something may have been binding somewhere. If springs were rattling around at full droop it is possible that something got cocked over and jammed.The ride was way too stiff and they were also pretty noisey without some sort of helper springs to take up the slack when the suspension unloaded.
Ground Control's sleeves are really very good and I like their perch clamp system better than anyone's. But I've had entirely less success with their upper mount "solutions". Some are OK, but others are just right out to lunch. So I'm not a huge fan of systems that attempt to cram a standard spring into an OEM spring perch; I'd rather see a proper upper hat and spherical bearing.
But that, as always, adds complexity and cost.
DG
This is the upper hat that he developed for the Saturn S series:
They have very nice tooling. Absolutely beautiful machine work. I haven't seen any reviews other than google info on Honda and 240 boards so I wouldn't trust it. Their Evo converted pieces look really nice, and they are spherical bearing upgraded, but looks good and performs good are two different things. Anyone have more links or tech review info?
I could link you to the raves that the Saturn owners have with them. I dropped out of the Saturn scene right after he made the coil-overs, front strut bar, rear strut bar. for the S-series Saturn. I owned one of his rear strut bars....excellent craftsmanship.
I usually just buy one and see what it takes to break it. Having access to a press can be fun!but looks good and performs good are two different things.
Note that upper hats on front McStruts can be tricky. You want to build in camber/caster adjustability and the thing has to rotate smoothly in the steering axis - and I don't think a single spherical bearing cuts it. The common sort of design I've seen really doesn't pass muster; there needs to be a separate bearing on the steering axis, and the camber/caster slots should feature positive stops instead of just relying on clamping power (six allen bolts pinching down is evidence that the thing moves)
DG
I agree.
1 word: Vorshlag. Lowest stack height, separate bearing on underside for steering, largest pillowball out there, and ability to have them in non-adjustable config (popular with us spec class peeps) so no worry about adjustment slipping. Not to mention they are a bunch of great guys and being down the street from AST USA. Mine for my next setup are from them.
