I haven't seen a general coilover thread, so let's do it. I'm looking for a thread similar to the 19T variant thread to get opinions and real world data if available. Let's keep it to 3S specific for now then maybe get into the Evo setups with the Supercar Adapters.
links are just for example, not necessarily cheapest
Tein:
Flex: Tein Flex AWD - Suspension - Pampena Motorsports
Spring Rate (F): 671lbs/in (12kgf/mm)
Spring Rate Adj Range (R): +2.0~-2.0lbs/in (112~-112kgf/mm)
Spring Rate (R): 336lbs/in (6kgf/mm)
Spring Rate Adj Range (F): +4.0~-2.0lbs/in (224~-112kgf/mm)
Benefits:EDFC, 16-Way adjustable, Spring compression/ride height separate
Cost: Expensive (comparatively)
Ksport
Couple different versions:
Kontrol Pro: KSport Kontrol Pro Damper System Coilovers - Suspension - Pampena Motorsports
GT Pro: KSport GT Pro Damper System Coilovers - Suspension - Pampena Motorsports
SPRING RATES:
Front: 8.7kg
Rear: 7.2kg
Benefits: Cheap, 36-Way adjustable, 1-year warranty
Cost: Leak/quality (fixed in newest revision?), QC and build variations
Megans
Supercar Engineering
SPRING RATES:
F: 62mm ID; 180mm length; 12 kg/mm (671lbs/in)
R: 62mm ID; 200mm length; 8 kg/mm (447lbs/in)
DAMPER SPECS:
F: 120mm stroke; 260mm length; M2 valving code
R: 115mm stroke; 240mm length; A1 valving code
Benefits: Cheap, 32-way adjustable, 1-year warranty
Cost: any?
Ninja Performance
http://www.ninjaperformance.com/prod...k73v4kes37jmg2
Spring Rate: Front 670lb/in(12kg) / Rear 447lb/in(8kg)
Cost: any?
KW Variant 3
Benefits: Compression/rebound seperate, Spring compression/ride height separate, 14-way adjustable
Cost: Expensive
BC Racing
BR Series: http://store.pampenamotorsports.com/...-coilover.html
RAM Series: http://store.pampenamotorsports.com/...-coilover.html
Never heard of these until I stumbled upon them at Pampena's site
CX Racing
http://www.cxracing.com/mm5/merchant...gory_Code=COVR
SPRING RATE:
Front 12kg(670lb/in) / Rear 8kg(447lb/in)
Benefits: Dirt cheap (seen as low as $650 new)
Cost: Get what you pay for?
D2
http://www.streettunedmotorsports.co...ers_3000gt.htm
Benefits: 32-way adjustment
Costs: Any?
Please link to any I missed.
