Results 1 to 10 of 25
Thread: Tire Experts - What's going on with this tire?
    |RLII Photography| Not Verified
    Rocket City, AL
    Just a random thread for today. A friend/coworker of mine had these Toyos on his Mazda 3 for about 15K miles when he had a blowout. He took the car into the tire shop and lo and behold 3 of the 4 tires look like this.
    What's going on here? My first thought is that the tread is separating from the sidewall. I could easily poke through the rubber between the two with a very small pocket knife. The tire shop is trying to get these replaced/refunded by Toyo under warranty.
    1994 Mariana Blue Pearl Mitsubishi 3000GT VR-4
    DR-650s and supporting, PST CFDS, Volk GT-Cs, Tein Flex, among other things
    Feb. 06 3SI ROTM - Best AWD BRG 07 - 3rd Place 2G 07 3/S National Gathering - People's Choice BRG 08
    BRG 2011 Total Package - NG11 Car Show 1st Place
    2010 Space Gray E90 335i M-Sport 6MT - 400whp/450wtq
    2002 Jet Black E53 X5 4.4i AWD - Bavarian Workhorse
    San Francisco
    I am by no means a tire expert, but isn't that an indication of negative camber and under-inflation?
    Support NG!
    Wow... I've never seen wear that sharp on a tire unless the tire failed or unless it was rubbing something.
    Frontline Fabrication verified
    Morgantown, WV
    Definatly looks like its rubbing on something that is way to sharp and isolated of an area to be camber issue
    Rocket City, AL
    I thought bad alignment and/or incorrect pressure until I inspected the tire myself. I tried to show in the first picture that the wear on the tread is pretty much all even. I also doubt that it's a rubbing issue because it did this to 3 of the 4 tires on the car (completely stock car also)
    Madison Heights, Mi
    Is that the inner or outer edge?
    If its the inner edge, Could it be making contact with the strut?
    Rocket City, AL
    Quote Originally Posted by Alan92RTTT View Post
    From what I know it's the inner edge of the tire. Again, 3 of the 4 tires from the car did this. I would almost say it's impossible that the tire is rubbing on the strut because the car is a bone stock, original suspension Mazda 3.
    Never finishes any verified
    Wake Forest, NC
    Quote Originally Posted by MeTarzan View Post
    Agreed, looks to be hitting the strut perch or something. The angle is just not right for a camber issue unless is hella or something ridiculous.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    you know you like it Not Verified
    Sacramento CA
    Is it the stock wheels and tire size? Because it is most definitely rubbing on something.
    Norcal3s.com supporter
    Nov 2011
    Bay Area, Cali
    it could maybe be an alignment issue. looks like that half of the tire is also worn down A LOT more than the other side.
