Results 1 to 8 of 8
Thread: Generic TT Stainless Downpipe QUESTION ?????
    Milwaukee, Wisconsin US of A !!!
    OK, I just bought A T.T. generic down pipe and S.S. pre-cat eliminators.
    I wanted to put them together before I install them and also because I went out and bought new hardened nuts & bolts to be sure I have everything I will need to complete new exhaust job to my car.
    But I have run into 1 problem, and by the looks of it everyone who went with this d.p. & pre-cat eliminator set up has.
    -On the down pipe, where the rear cat-eliminator connects to it, which 2 of the 4 holes should I use??
    -Also where the rear cat-eliminator bolts to down-pipe the hole center to hole center is about 1/4" wider on the down-pipe (it looks like it was designed for A heat riser to be in-between the 2 flanges) than on the cat-eliminator, so what has everybody that has this type of D.P. done to make it work??
    I probably do not have to post up pics but I will anyhow.
    Thank you, RiZ
    TN
    Need to know what year car you are putting it on. That looks to be a 2nd gen rear precat... but you will need to install that before putting the downpipe on. Once you get the rear precat on, then bolt it to the downpipe.
    Dandridge, TN
    I don't know offhand which holes you're going to want to use, but I assure you that the rear cat eliminator will be far easier to install if it's not bolted to the dp when you do it.
    Apr 2011
    buffalo NY
    What year is your car?
    1991 3kgt sl, all forged internals, 450cc injectors, 13t's, eBay turbo back, walbro 255, hks ssqv bov,turbo smart mbc, 3sx fuel loop, 3sx polly mounts, 3sx dual core rad, FMIC, 99 big bore lifters, xtd stage 3 clutch
    Thank you for the answers,
    My car is A 1992 Dodge Stealth R/T.
    I am not planning on installing it as 1 piece put together, but.... I do want everything to fit when I do go to install this on my car.
    That is the reason for my questions, I am tiring to put it all together with new hardened bolts so when I do install it I will have NO problems.
    So I am guessing that the holes will have to be drilled A bit larger. To be able to bolt the rear cat eliminator to the down-pipe.
    It is just that the rear flange of the down-pipe has 4 holes, and the flange of the cat-eliminator that connects to it has 2, also the bolt pattern is about A 1/4" wider on the cat-eliminator.
    Thank you very much.
    > > > > > RiZ < < < < <
    Thanks, RiZ
    Quote Originally Posted by Valhallaz View Post
    Yes, I was not even considering installing the down-pipe with pre-cat eliminators bolted together. I just want to get this problem handled before I do the install. and it is A good thing I tried to bolt it all together other wise I would not have found this issue.
    Its A 1992 stealth by the way
    thanks RiZ
    TN
    Alright, can you possibly mental fab this up, like you are attaching the rear precat to the turbo? Once you do that, you can figure out which holes to use.
  8. The Following User Says Thank You to dbest671 For This Useful Post:
  9. #8
    Thank you very much appreciated.
    RiZ
