Hello, I drive a '95 mitsubishi 3000gt sl turbo converted, and i am having issues with my car running like crap. It just started running really lean (between 15.8:1 and 17.3:1) and sounds like its not running on all cylinders, but it is.
I checked to make sure each cylinder was firing and killed spark to each cylinder, every cylinder passed. I killed individual injectors to each cylinder, every cylinder passed. car starts fine, and runs and drives, just really lean and sounds like crap.
The car has over heated (gauge pegged) twice now within the last month due to a fan failure, which is now fixed. however, the car ran perfectly fine after each over heating, other than a ridiculously high idle (2000 RPM). The car has always idled a little high ever since i converted, it around about 1500 high idle and settles to anywhere in between 1000 and 1200 RPM.
I just put a new rack and pinion, power steering pump, front and rear motor mounts, radiator fan, and custom turbo oil return lines, as well as an alignment. Car ran fine after the work was done. the only odd thing i had happen was i had to unplug my single O2 sensor to drop the exhaust and forgot to plug it in before running the car. Which should have set a check engine light but did not.
My current suspects of the problem are either my cam senor melted and distorted, or my ecu is failing. When i put the ecu in the car i opened the case to check the caps for leakage, someone had rebuilt it but it wasn't done very cleanly.
I am a tech in training at a shop, and do all my own work on my car. so if any additional information is needed, it can be supplied. I am working in the dark without being able to scan the car and get engine data so any help is appreciated.
