Results 11 to 20 of 31
Thread: Timing Belt Problem
    rings are not seated yet?
    I tested them before the cams were installed and it had around 15% on every cylinder.
    could the lifters be pumped up too much? I primed them rock hard before I installed them.
    ok I pulled all of the rockers and re-ran the test. Every cylinder is between 10 and 20% leakdown.
    Not sure what is happening, but it isn't bent valves. Once this thing is broken in I think it is going to be good and tight.
    Unless someone has some ideas I think I'm going to put the rockers back in and move forward.
    Member
    Chilliwack BC
    What did you prime the lifters with?
    I wouldnt prime them with oil initially, they'll overpower those little springs & hang the valves open.
    FSM suggests priming with diesel, the purpose in that keeping the air out & allowing them to bleed off statically to the correct preload.
    I did prime them with oil, I thought I'd read on the forums that it was fine to use oil if they weren't dirty and you weren't trying to flush them out. What's the solution then? Prime them with diesel? I can't remember hearing about someone having this problem.
    Here is a quote from Chris Hill:
    Quote Originally Posted by Import Power View Post
    It's better to put them in not primed. If you put them in fully primed they will be over extended and valves will hung open. They will quickly pump up and adjust to the level they need to be at.
    The lash adjusters shops are selling are not OEM and are shorter than stockers especially when bled down. Which makes it easier to toss a rocker if one were to bleed down.
    If you have stockers, just clean them by pumping diesel or ATF thru them. Even if they are 1st gen. 1st gen Lash adjusters aren't noisy because of design but because of being dirty. "large bore" lash adjusters will get noisy just as fast.
    -Chris
    I wish info was consistent. I'm going to de-prime these things and get on with assembly.
  8. #18
    Andover, MN
    You don't need to prime the Lifters, all you have to do is soak them in some oil for 15 minutes and put them in. I use the rest of my 75W90 gear oil and soaked my lifters before I installed mine. You may get ticking on warmup but it will go away.
  9. #19
    ok, I pulled all the lifters and bled them off. Reinstalled the rockers and this thing is timed like a clock.
    90% leakdown. WTF. I don't really know what to do next.
  10. #20
    When you do the leak down test are you hearing the air coming from the intake or exhaust? Definitely sounds like the cams are putting pressure on a valve. You might not be exactly on TDC or the cam gears are causing one to open a tad. Try and wiggle the cam gears during the test.
    I think I would run it then test it again after some break in.
