i have a feeling its in the tune somewhere ,
Basics first. Fuel, Spark, Compression
it has fuel spark compression lol . turned out the timing was off alittle and then the plug wires were on the wrong coils. which i knew might be a problem because i have my own mount for the packs hard to tell which two went where. but i had it running today!!! fixed a tranny cooler leak and an oil leak. have to take my water pipe to get re brazed it was leakign but other than that seemed good
Nice. Knew it was something simple.
now i just need some rad fansso i can let the tranny warm up and get the fluid it needs , right now it seems to engage reverse immediately, but in first you have to give it some rpm , part of that is prolly the stall but i ran out of fluid. a health cooler line leak didnt help that cause any. part of it might be the stall converter as well its set to stall at 3500 rpm.
going to the dyno in kc to get tuned on the 24th! 600 whp here i come maybe lol
saturday is the day pics and vid wiklkl follow when iget back sat night!
went to the dyno today..... let down .... only made 300 awhp and 240 ftlbs before my driveshaft decided the carrier bearings are shot. and we had to stop . sad day
Lame, but at least it's not a difficult nor expensive fix![]()
