so i have not started a build thread on here for my talon and not to steal bigtylas thunder but heres alittle back story on the girl.
Purchased for 500$ a decent 93 TSI Auto with intentions of making a 10sec drag car out of it . Car was ready for the scrap yard in most peoples eyes, junk interior , engine was mostly in the trunk.
So i tore it down , everything out of the car completely . all suspension subframes everything came off . I have replaced everything unless noted
Suspension/Brakes/steering -
Kyb shocks
all new bushings on everything
manual steering rack
Rear toe fix
adjustable upper rear control arms
Front 92 3S TT brakes (rotors , Calipers, Hawk Hps Pads)
8 Point roll cage custom built.
5zigen fnoirc 17" rims
Engine -
2.0 Block .20 Over
Wiseco 9:1 pistons / W ross rods
FFWD Butcher crank (knife edged and lightened)
ACL race bearings
Slow Boy Stage 3 Head , 1mm over valves , ffwd springs and retainers , solid lifters
BC 288 cams , findanza gears.
Balance shaft delete.
l19 head studs , and lower end studs
South florida performance t3 mani
holset hx 35 7blade turbo
tial 38m wastegate w/ jays racing bumper exit kit
custom downpipe/ exhaust
Slowboy (old style ) race fmic
10mm plug wires, custom coil bracket
Sheet metal intake (forgot brand )
Fuel -
fic 1680 injectors,magnus fuel rail
-10 an feed lines , aeromotive fpr , -8 return lines
aeromotive 1000hp fuel pump and filter.
(forgot the brand , custom fuel tank) fuel cell mounts in stock location and uses stock filler.
Tranny -
rebuilt by myself with IPT rebuild kit (uses more clutches ect )
shift kit , stall converter.
Body -
Had the hood , bumper and left fender replaced and repainted.
The rest the pics will speak for themselves.
im sure im forgetting a ton of stuff , thats what happens when it takes you two + years to build something
