Results 1 to 6 of 6
Thread: syncro
    Jan 2011
    az
    syncro
    hey guys, i have a pretty bad 2nd gear syncro. it grinds hard if im really on it when shifting. but when i drive slow and shift to 2nd, it doesnt grind. is there good gear oils out there that would reduce the grinding. i do plan on replacing it soon, but not at this time.
    also, my shifter is pretty stift as well. any input would help. thanks guys.
    August 2003
    Uniontown
    It could actually be your clutch not fully disengaging too. Easy way to test is start your car, warm it up, and get on a good level surface. Now, with your car in gear, sitting still with out your brakes on, press the clutch in and rev the engine close to red line. If your clutch is not disengaging fully, your car will begin to creep. Don't let go of your clutch pedal, your not trying to launch your car, and don't hold it at that high rpm for more than a quick second.
    If it does creep, bleed your slave. If it doesnt, change your fluids. A lot of people have liked BG syncroshift. Hope this helps
    Jan 2011
    az
    coo. ill try this. thanks
    Bamberg, Germany
    You can also try putting oem Evo MR fluid in the trans fixed my slight grind on my 94 R/T
    3000GT of Europe
    www.3sofeu.org/main
    Cherry Hill Mitsubishi Coupon Code- 3SE
    Jan 2011
    az
    Quote Originally Posted by ntcmpjg View Post
    alright. ill try both ans see what happens
    Make sure you get the Evo MR fluid for the Evo 8/9, not for the 10. The 10 uses something entirely different and will destroy your synchros.
