Results 1 to 10 of 18
Thread: What would an AWD swap be worth/ whats needed???
    Like the title says, im trying to figure out what a AWD swap would normally be worth and what parts they normally include.
    It can be as simple as the rear brackets and subframe, or a full tt chassis swap with tranny, transfer case, driveshaft, front knuckles, and a oem TT suspension with lowering springs.
    Just trying to figure out a good way to sell off some parts, if its worth it i'll sell it all in one big package.
    thanks
    -Austin
    And the list goes on...
    Well there are different ways to do it.
    Mine
    http://www.3sgto.org/f17/awd-convers...-build-54.html
    Shooters (I did mine like this one)
    One day AWD conversion finished! (lots of pics) - 3000GT/Stealth International Message Center
    Shooters 100% conversion
    http://www.3si.org/forum/f1/shooter8...-heavy-427498/
    This is a list of people that have done it. He hasn't updated it in a long time.
    FWD to AWD converted cars.. How many are there now? - 3000GT/Stealth International Message Center
    You could gauge interest before cutting the car up. I know Jason (PMP) was cussing me when he cut the front rear subframe mounts off for my car.
    the most popular (imho, easiest) method of doing it involves cutting the mounts off the donor car. not really a good idea for a frame you want to continue to utilize.
    I know how to remove the parts, just wondering what people usually pay for the swaps, and what they usually get. Im trying to sell all the stuff.
    Cool idea, Austin. I'll be impressed if you find a profitable way to sling kits.
    Quote Originally Posted by Austin@STM View Post
    Sorry, I was just trying to show it depends on how you do it for what parts you need. I have no idea on a package thing. I don't think I've ever seen an AWD conversion sold as a package. I'd just make a list of everything and look up what people are getting for the parts then cut a % off for buying all the stuff.
    BTW if this is a donor car you are cutting up I'd be interested in the rear mounting bolts for the rear subframe. I just had some AWD ones cut off, drilled out and threaded but I'd like to go through the top and replace them with the AWD ones.
    No problem, I appreciate the help. Just wondering really if anyone had a number in there head. I have no idea what a package deal would be worth.
    Kind of like a TT conversion, non really have the same parts. Like an ECU, radiator, etc.
    Trans
    Flywheel
    transfer case
    Driveshaft
    Rear subframe and rear diff
    AWS delete or TT power steering pump and rack.
    Subframe Mounts
    Front knuckles, half shafts, TT breaks
    Some of the things you can offer for an AWD conversion off the top of my head.
    i paid $900 shipped for the rear end i needed. came with subframe, 6-speed rear, struts, brakes, mounts cut from the frame. i considered that a fair price--since everything was in plug & play shape.
    add in a transmission, differential, transfer case, aws delete, etc....and you start adding quite a bit more. even in used condition, i don't think you'd really make any profit off ALL the stuff necessary to do a FULL awd conversion, unless you were charging at least $2500-3000. and that's a fair estimate. it's also why i still say everyone should SERIOUSLY consider buying a vr4, rather than modding a fwd.
