as we were pulling the heads off, i broke the knock sensor ecu harness connector. the one on the actual engine harness, not the knock sensor itself. so i spliced in another connector. i did the same for the knock sensor itself so that the 2 connection mated. do you guys think this will work or no? i can always buy a new knock sensor but it wont work with the connection because it broke?
