Page 28 of 40 FirstFirst ... 18262728293038 ... LastLast
Results 271 to 280 of 396
Thread: It is time for my comeback... 2000-2500lb cornerweighed 3/S and 1000hp motor
  1. #271
    Pueblo, CO
    i know. The thought of having this technology and 1 off stuff is absolutely impressive, but i highly doubt Ali would be a happy camper if someone spins him out or he smakcs the wall and time to get a new hub...or two... Atleast, my turbos arent that expensive lol.. Jer this thing is amazing, but id rather keep it on the trailer so nothing happens to it jk
  2. #272
    Banned J. Fast's Avatar
    Nah... runoff will just be tires. The subframe and suspension to ground height clearance is actually higher than the stock location. And the underside will be completely enclosed by an undertray. Front, all the way to the rear.
    Seriously though, I looked at all the geometry and the cad data upload into simulator with angles. You just can't correct the tie rod and control arm to upright angles without changing the entire hub assembly and subframe pickup points or adapting a rediculious shim and bumpsteer correction kit (that no one has ever produced BTW). If you don't you want 2" of shock travel you have to change the upright. You can't fix it with just the subframe alone. You want to have suspension travel the height of a $1 bill?
  3. #273
    I hope it works out for ya buddy. (slowly inching closer to getting my 5 bucks from Ron, LOL)
    www.stickyvinylgraphics.com
    Custom Stickers & Graphics
    www.chumpcar.com
  4. #274
    Pueblo, CO
    Jer, all i know is, spend $600 on 2 go pro cameras one in cab and one out so we can see this shit when your ready to get her on the track
  5. #275
    No you didn't make that bet did you... you bastard! I'll still be racing... I'm on a 4 stage build plan with 3R.
  6. #276
    Haha... I can't afford that shit! They're smakkin' me 5K at a time...
  7. #277
    Competitive by September. (the clause of the bet is the word *competitive*, within 5 seconds of the field time) What you need isn't parts, it's seat time and then more seat time. Then, when that's done, add another mega bucket of seat time. The biggest adjustment that will need to be done is the "nut behind the wheel".
  8. #278
    Wait, wait, 5k at a time?! Jer, WTF are you doing man? That's waaaaay crazy.
  9. #279
    I'm building a competitive racecar... not a racecar with tooner parts
  10. #280
    I'm not building a car to show up and run. I'm building one to show up and win. My out of pocket on this really isn't that bad in the scheme of things. The only thing I've had to buy so far is the cage material, turbo's, some gaskets, and the paint. I've traded for nearly everything, and the chassi was gifted to me. I'll spend 30K on this car tops. That's still significantly less than what's vested in my streetcar and much less than... blue velocity... Edit... and the purple people eater!
