...in the spring, and I'll be wanting to do the defroster vents at the same time - I'm confused as to whether the stockers can be mounted from the top (considering the optimized access), or if I need to go with an aftermarket version?
If you're going to go with stock, having the windshield out won't make a lick of difference, as they screw in from the bottom, dash removal is required. If you go with the 3SX ones, those you can do from the top.
If you plan on keeping the car for a very long time, I'd go with an aftermarket version unless your car is a weekend warrior and garage-kept.
You can do the install with the windshield out without having to remove the dash for the aftermarket versions.
Thanks, guys - exactly what I wanted to hear.![]()
