Results 1 to 6 of 6
Thread: Need Help! Dash issues.
    No Show NG11 Not Verified
    Mesa, AZ
    Yesterday, I changed out my old turn signal housings with clear ones from 3sx. At that time everything worked. Today I come out and my blinkers, windows, tach, oil pressure and everything else minus the gas and spedo have stopped working. The car lights themselves still turn on and the car starts. But, i am at a lose as to why something so simple may have caused this.
    I have gone through and checked the simple fuses. They all appear to be fine and i think all I have left is the relays.
    Any input would be greatly appreciated.
    Your 1993 Mitsubishi 3000GT SL is one of 4310 that received VIN numbers. Based on the order of the serial numbers, your car was the 2685th out of the 4310 that were made that year.
    Mesa, AZ
    All is well now.
    The Big House.
    What caused the problem?
    blown fuse?
    Mesa, AZ
    A semi blown fuse? Best way to describe it. After going through and pulling all the fuses, there was one that looked fine. I even got a green light from my tester on it. But after some time jacking about trying to sort the issue I just decided to replace every fuse regardless. Got to that last one and everything kicked back on.
    Side note, I still can't think of a reason why changing out the blinker housing with new ones caused this issue. Anyone have any ideas?
    coincidence. just happened to happen at the same time, making you think it's correlated.
