Hey greg i know i asked this before and i have messed with the tables
just want to make sure im getting it right
Startup tables
At the end there u say to just cut the values in half if your running bigger injectors
which particular table are you talking about ?
or is it all of them?
Intake section
MAF pulses per stroke 13.06
does this get changed with the evo maf??
active exhaust
so on first gens we need a wire from one side of the conversion harness to the other
to make the switchable active exhaust work?
so pin75 on the flash ecu to pin?? on the 1g harness
also if we use pin 7 to trigger an electric cutout is there some sort of timer cutout ?
or will it continue to hold the cutout motor in the open position possibly burning out the motor also how would it trigger the close?
Kx
