A while back vr4whore was searching for a flashable ECU, no VR4 ECU or SL ECU, or cloned ECUs were available for purchase. He asked for help in locating a flashable ECU and the only thing available at that time was Montero ECU and nothing else. There are many Montero ECUs available each needing different hardware modifications. I recommended vr4whore to purchase the same Montero ECU part number that Jesters Deadd sold a while back as a good starting point (
3000GT/Stealth International Message Center ). It reads
"I have a MD343513 which is the 98 Montero LS ECU. It has the knock sensor and two O2 sensors. This is probably the third best ECU to have for the flashing ability that the 98-99 VR4s have. THe first being the 98-99 VR4 ECu, the second being the 98-99 SL ECus."
There is absolutely nothing wrong with my recommendation, it is still correct. It just needs more work than a 3000GT VR4 or SL ECU.
I have already told vr4whore his stalling is from the open BOV, he went from speed density to MAF.
One of the reasons his car is running lousy is because he did not address the low/high voltage fuel relay pump. His fuel pump will run at low voltage because he does not have a VR4 ECU to switch over to high voltage mode, and is dangerous to drive like this. Replacing the low/high voltage fuel relay with a jumper wire arranged such that the fuel pump receives full voltage is a quick and easy fix. This is not optional, it must be done. "Boosting gently" will cause fuel starvation and the car will drive horrible as expected.
Flash tuning is a bit intimidating for some people, so I will generate a flash rom image with their injector size, injector latencies and disable some peripheral bits to get them started.
Using HHH-Hybrid to pull codes on the 98/99 flash ECU does not work correctly, and the error codes they generate should be ignored as it will lead you astray with misinformation. To pull codes reliable use OBD2 mode only.
To fix v4whore car I would do this:
(1) Get that low/high voltage fuel relay replaced with a jumper wire.
(2) Get that open BOV to closed/recirculated BOV.
(3) Get a WBO2 controller and disable all O2 (open loop mode only). My car has been running open loop mode only for more than a year and to my surprise it works very well in this mode. The best part of open loop mode is that no O2 circuit modifications are necessary. A WBO2 is needed to verify open loop mode is working fine and if not, adjustments to the injector scaling can be tweeked to make it so.
