Page 90 of 166 FirstFirst ... 40808889909192100140 ... LastLast
Results 891 to 900 of 1658
  1. #891
    Just wanted to get this out there. When flashing the "fa" processors you have to add the "a" to the memmodel in the XML file.
  2. #892
    Medford OR
    Quote Originally Posted by 99 vr4 View Post
    Yes the front O2 in evoscan is really the rear... That is fixed in the new version xml.
    Actually, EVERYTHING labeled front is the rear... Fuel trims, afr, idc, latency, etc, etc.
    The evoscan guys aimed that the primary was the front and in reality three primary is the rear...
    They probably used the same settings as the 3G Eclipse.... All the newer V6 stuff is mounted backwards, and the trans in on the wrong side...
  3. #893
    Oct 2010
    St Louis
    Well yes and no.. The left side of the motor is primary... And the assumption was made on our platform that the front bank was primary...
    www.ClonedECU.com
    The home of the Original Clone and Clone2 ECU!
    More Plug n' Drive and less Plug n' Fail like the others!
    Remember, if it's not a Clone, it's just a copy!
    Get Chromed!
    Donate Now and receive a coupon code for the amount of your donation (up to $50.00 US) which you can apply at check out for a Clone2 ECU, Plug n’ Play Harness, or Clone2 Plug n’ Play Package!!
    1999 3000GT VR4
    Glacier Pearl White
    Yeah it's stock . . . trust me
    How To Contact Me:
    eMail: brett_farnam@yahoo.com
    US3S/3SGTO: 99 vr4
    3SI: bfarnam
  4. #894
    Medford OR
    I agree a mistake was made, I was just theorizing on how it may have happened... Since the newer stuff has the left bank in the front, it would be easy to do.
  5. #895
    Oct 2010
    St Louis
    Yeah you might be right... I know on the older evoscan it was reversed as well, before the later model eclipses were in play
  6. #896
    DC Metro Area
    So, I was tearing apart my door to replace a speaker and for some odd reason, the connector looked identical to the stock BCS wiring (And a few other points in the engine bay). Quick google search lead me to speaker harnesses, gonna check to see if that can be used as a part of a pigtail to wire a resistor and plug directly into stock wiring.
  7. #897
    Oct 2010
    St Louis
    I made my adapter using standard 1/4" spade terminals.., they plug right in and they're cheap
  8. #898
    West MI
    Just wanted to say my car is running great now, a big thanks to Aaron for figuring out my o2's were switched around, doh! And thanks to Greg as always for everything.
    One thing I did notice though Greg is my factory boost gauge no longer moves from the bottom with this version of chrome, it worked with the old. I haven't gone through the periph's yet to see if its in there, really not a big deal to me, just thought you might be curious.
    92 3000GT VR4
    Matt
  9. #899
    I wanted to say thank to the guys who have done all the leg work on getting this up and running. I have a question about the MAP sensors for 1G conversion. I understand it's needed to control boost, but has it been verified that we can use this?
    STM: INTAKE MANIFOLD SENSOR ADAPTER | 95-99 DSM | EVO VIII-IX
  10. #900
    July 2005
    Arkansas
    Quote Originally Posted by sublime_whatigo View Post
    Do you have an aftermarket map sensor installed?
    If the answer is no, then you need to change the Boost Gauge Load -> PSI conversion box, under the boost gauge section, back to 0xB6.
    If the answer is yes, then I have no idea
