I finally installed my 560 evo injectors, and noticed something interesting. The o2 sensor labelled as rear (which is actually the front sensor, as someone else pointed out), was not oscillating as expected at idle, and the o2 trim feedback was "stuck" at -25% and would not change. When I would rev the engine the o2 sensor would then oscillate/respond, but at idle it would go back to reading lean (near 0). The o2 sensor labelled as front (actually the rear), was oscillating normally at idle, and the o2 trim was changing.
So I swapped out the o2 sensor that wasn't oscillating, and the same thing occurred. I swapped it out again with another sensor and still the same thing. At this point, I was suspicious of something in the ecu code because it was unlikely 3 o2 sensors were bad. I have several of the periphery bits disabled because I have removed EGR, EVAP, rear o2s, etc and so I wondered if one of those was causing it. Anyway, I went back to the stock tune, and only changed the fuel injector size and latency tables (I did not alter any of the periphery bits), and as soon as I started the car both o2s were oscillating like they should. After some troubleshooting, I found that it was periphery0: bit02. The name says that it disables downstream o2s but apparently it does more than that.
