Page 72 of 166 FirstFirst ... 2262707172737482122 ... LastLast
Results 711 to 720 of 1658
  1. #711
    July 2005
    Arkansas
    Quote Originally Posted by NOMIEZVR4 View Post
    Hey I resolved my issue. The harness had 3 wires switched around which was causing the car to act funny throwing the CEL's. With the help of Brett(99vr4) and a friend of mine, we were able to fix the harness. The wires were switched to how they are supposed to be and the car is running great! Actually feels a bit more peppy with the new ecu...
    However evoscan doesn't work...ill post a screen shot of what the error message says. Hopefully we can get that resolved as well.
    I'll be sending a donation soon.
    Make sure you have OpenPort 2.0 checked, and Mitsubishi MUTIII (not the 3000gt one).
  2. #712
    Oct 2010
    St Louis
    So I have successfully been running stock boost control with 450cc injectors, 482 "evo" maf, and 15g turbos. I can run from wastegate to 16 pounds with no problems. In order to get the stock boost control solenoid to bleed off enough air, I needed a restricter in the boost line. I made one with a nylon screw and a #60 drill bit.
    BTW, this is on one of my new ECUs...
  3. The Following User Says Thank You to 99 vr4 For This Useful Post:
  4. #713
    www.chromedecu.org verified
    DFW
    Quote Originally Posted by 99 vr4 View Post
    Great news. btw how long was the screw you used? I think the length will make a difference on the supply rate to the wastegates, so I am just clarifying. Also did you use the stock solenoid. I know you were experimenting with other solenoids.
    Hmm this makes me think... you could just put a MBC in the boost line and it would still work with the stock BC too.
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  5. #714
    Oct 2010
    St Louis
    I used a nylon #6, cut about 1/8 inch. Then drilled a #60 hole through, then I drilled half that again with a 1/16 (btw, tried that size first, it was too big).
  6. #715
    Born To Build
    June 2009
    Central, MN
    Been following this thread for awhile now, looking really great! I plan on running a chromed ecu this next spring. Already purchased the harness.
    I did have one thought though...would it be possible to figure out a fix for rich shifts when running an open atmoshpere bov? I dont see any way of doing this without converting to Blow-Thru/speed density but I thought id ask just in case.
    -1995 Dodge Stealth RT/TT Blue Pearl "1 of 7"
    Full ATR exhaust, Gutted Precats, Blitz DSBC, K&N FIPK.
    Soon To come: 15g's and supporting mods
    -1991 Dodge Stealth RT/TT - Sold
  7. #716
    Relocating to this thread from the "other" board.
    Steve
  8. #717
    Medford OR
    Playing with the orifice size is a great way to help tune out boost spikes or creep.... Just for reference, the #60 is .040", the stock one is pretty close to .030". Also, the smaller the orifice, the more drastic the changes will be with a change in duty cycle. (I.E. a car that operates at a max of 15 psi will have tighter control and adjustability with a larger orifice, where a car that operates at 25 psi will need a smaller orifice to facilitate dumping that much pressure)
    I realize I'm not telling you anything you don't already know, just throwing the info out there for the readers...
    I went through the same process building a cheep bleed style MBC years ago, and ended up with around .040" as well.
  9. #718
    The periphery needs to be disabled thus disabling the entire purge system.
    I'll update my purge control thread with details.
    I've running Chrome 1.1 with a EVO X map installed and tied into pin 92, and I'm getting the constant purge valve clicking. I've matched my periphery bits to those shown by aaronatstate, but still get the clicking. I can't find the referenced purge control thread (I did look). Does anyone know how to disable it in the ECU or do I need to simply unplug the solenoid?
    '95 Spyder VR4:
    Exterior/Suspension: '99Front End/Rear Garnish; 19x9 370Z forged Rays Eng wheels; CF 575 Hood; Tein S tech (front) and H tech (rear) springs with rear adjustable control arms; Adjustable Front Tein Pillow Ball Mounts.
    Interior: Hella TPMS; LCDBC; Remote Top; Interior Rearview Mirror with Temp/Compass/HomeLink.
    Brakes: DBA 4000 Slotted Rotors - HPS Pads - SS brake lines.
    Performance: Pampena Bell-housing reinforcement; Pampena pistons; Ninja Lightweight Rods; Dynamic Racing Stage 3 heads and Billet DR650s w/9 Blade turbine and Billet actuators; ported I/E manifolds; DSM SMICs; ID1000s; Flashable ECU ('98) - Chrome 2.0; GM 85mm MAF & translator; 3SX Downpipe; IPS Quad tip exhaust; Walbro 450LPH E-85 fuel pump; K&N fuel filter; AEM AFPR; ACT pressure plate MB019; Maximal/Setrab Oil Cooler; 3SX high capacity radiator; 3SX adjustable cam gears; 3SX Poly mounts; HKS Twin Power.
  10. #719
    JNS Engineering verified
    San Jose, CA
    I've got the 99 clone ECU and a harness ordered. How is Chrome V2.0 coming along? I want all the emissions stuff on the 95 to work like stock.
  11. #720
    I lack color... verified
    Aug 1998
    Quote Originally Posted by awdonly View Post
    http://www.3sgto.org/f2/disassembly-...nsor-8260.html
    Looks like you posted in this thread too.
