I would need some convincing to get this over the DR Arc-2. This just seems like more work to me and it isn't proven for the power I want to run yet.
Hmmmmmmmmmm
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
It's been a while since I've used one but last I remember the ARC doesn't give you things like Launch Control, NLTS, accurate boost gauge, precise fuel and timing control, idle control, accell/decell enrichment, knock sensor calibration, radiator fan control... On and on with all the features I've posted about.
If you don't understand any of the below posts feel free to pm me as I'm sure Greg would appreciate we take this discussion elsewhere.
Since overheating a part is far more likely to damage it than normal use, and mutliple sessions of soldering and de-soldering are more likely to overheat the part than normal operation I think its pretty self explanitory. And as the post below points out, new parts are cheap so why chance it by re-using old ones. I would be curious to hear what constitutes "proper handling" of components like this though. My experience has shown these things to be fragile as compared the thru-hole parts.
And as a second source of perspective, the guys that build the drives in our labs won't re-use parts like this for rework, they use new. If someone that knows better than me tells me that option B is better than option A than I will trust the knowledgable folks.
I think this explains a lot, and in a nut shell you are not understanding me.
No one is limiting the ecu's you can use or advocating that we ignore other sources, its quite the opposite. All questions of proper ecu functionality become moot when the components on the "clone" match the true ecu. And this type of re-work and modding makes non-3/s ecu's perfect options.
My statement was one that was echoed by JimVR4, the better option is to use new. But by no means is it the only option that will work.
sorry if I am taking you the wrong way. I'm just seeing constant criticism of pretty much anything that pops up here on the hardware side. There is reason to be careful, but a lot of these statements are leading to mis-information being spread and people thinking for instance that an SL ecu will not even run the car.
