^^^thanks..I just found your old post on page 22...![]()
Let me know if you're still having problems after you set the peripheries...
Aaron - you are running a Montero ECU, no?
These are exciting developments, particularly if ECUs from multiple platforms can be integrated seemlessly.
What's the largest injectors you can run with a chromed ECU on totally stock engine and no hotwired pump? I plan on switching to this in the near future, and need new injectors, and wanna go with the largest I can on stock, rather than goin with somethin medium sized, then needing to upgrade the injectors again, later on down the road.
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
WG psi on 9bs n pump? No idle issues or other drawbacks/side effects?
Sounds awesome, I need new injectors, a couple are bad, and am planning on switchin to Chrome ecu so I was gonna try n save the money and hassle if possible and just get the largest injectors that I'll ever need for my HP requirements
Adam - can you go over what is involved in converting these Montero, Diamante, and SL ECUs for use in the VR-4? Any idea on the pricing of these services?
