Page 44 of 166 FirstFirst ... 3442434445465494144 ... LastLast
Results 431 to 440 of 1658
  1. #431
    www.chromedecu.org verified
    DFW
    Are you talking about triggering the pump thru the relay in the cab or the one in the engine bay?
    The relay in the cabin has to be on for the pump to run on hi or low. It send power to the relay in the engine bay. The relay in the engine bay only redirects the power through a resitor to make the pump go to a low setting. So to prime the pump you should only turn on the relay in the cabin.
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  2. #432
    I lack color... verified
    Aug 1998
    Antero sent me a couple extra pins and I wired up my aem uego to pin 93 tonight. It reads fine in evoscan, but do I need to ground the sensor output on the aem to anything?
    All the ECU sensors are tied to the same ground so they all read the same. Though you can get away with grounding the AEM to the chassy, it's best to use the ECU ground.
  3. #433
    Oct 2010
    St Louis
    Sensor ground.... Not ecu ground... different pins.
    Also don't tie sensor ground to ecu ground or to chassis ground... That would be bad
  4. The Following User Says Thank You to 99 vr4 For This Useful Post:
  5. #434
    thanks guys, looks like pin 72 on the 91-93 harness, pin 49 on the 99 harness side.
  6. #435
    Man vs 3/S verified
    Kingston, WA
    Super bummer. My car has a 97 ECU in it..... harness is hacked to hell, lol. There was no reason for me to think there wasnt the 98 in the car. Car used to have an AEM, a buyer before me didnt want it, a 97 ECU and harness got put back in....... Needless to say I am pissed.
  7. #436
    Oct 2010
    St Louis
    That sucks man. So they pit in a whole new dash board harness or did they cut and hack on a 97 connector?
    Did you just buy this car? If so you need a refund.
    And if they just cut and hacked the harness in there... You really want to not use an adapter... Your going to want to rewire new pigtails in to ensure it is not screwed up our had a bad confection.
  8. #437
    Thank You everyone working on this, I chrome my 98sl ecu and i am getting great gas mileage normally i would be less than a half a tank. Now i'm at a little over 3/4. Cant wait to get some real turbos on it and get into the tuning aspect of things.
  9. #438
    Aug 1998
    Quote Originally Posted by fridayda13th View Post
    thank you everyone working on this, i chrome my 98sl ecu and i am getting great gas mileage normally i would be less than a half a tank. Now i'm at a little over 3/4. Cant wait to get some real turbos on it and get into the tuning aspect of things.
    win!
  10. #439
    Keeping it real...
    Oct. 2006
    Reno, NV
    You going to show up to the cruise and dyno meet next month?
  11. #440
    is there anyway to alter the scaling and set things up so that we can log a greddy map sensor? The wideband logging was a piece of cake btw.
