i think 2.9 is out if that works
hey Greg is there any way you can set it up to prime the fuel pump before the ecu sees a cranking signal?
"I never knew I could drive like that. I was going faster than I've ever gone before, and yet, it all seemed to be happening in slow motion. I was seeing three and four moves ahead, weaving in and out of lanes like an Olympic skier on a gold medal run. I knew I was challenging the very laws of physics."
Greg,.did you find this yet? MUT A2 bit 1 - Crankshaft sensor pulse MUT A2 bit 4 - Cam sensor pulse
I did find the cam and crank signal bytes some time ago. I will double check if those are the MUT address they are assigned to.
Edit: Yes they are.
Antero sent me a couple extra pins and I wired up my aem uego to pin 93 tonight. It reads fine in evoscan, but do I need to ground the sensor output on the aem to anything?
