Page 42 of 166 FirstFirst ... 3240414243445292142 ... LastLast
Results 411 to 420 of 1658
  1. #411
    I lack color... verified
    Aug 1998
    Quote Originally Posted by jras312 View Post
    Nope. Only things relating to airflow or load are as follows;
    -Airflow Rate gm/s
    -Airflow/Rev
    -Air Flow Hz
    -Load MUT 2Byte Mod
    -Airflow MUT 2Byte Mod
    -Load Calculated
    -Load11Bit4
    -Load 1Byte
    I don't know if I just did all the steps completely wrong or what but I'm confused.
    very quick. Take a screenshot of evoscan and post it. I also need a screenshot of your MUT table.
  2. #412
  3. #413
    Aug 1998
    Ah, that's what I thought. you're still using the EVO XML for EVOScan, not mine.
  4. #414
    Aug 1998
    that's also why you can't log your wideband either.
  5. #415
    Dec 2011
    Iowa
    Your data file is under the datasettings folder in EvoScan, what could I be missing?
  6. #416
    Aug 1998
    You have to replace the old data xml with mine.
  7. #417
    Dec 2011
    Iowa
    I have....
    the data xml files is under both; program files (x86)>evoscan>evoscan v2.6>datasettings AND program files>evoscan>evoscan v2.6>datasettings
    What am I doing wrong. The screen shots I had were of the data xml file that I got from you....
  8. #418
    Aug 1998
    I have....
    Windows 7 and Vista have a feature called UAC. It makes a duplicate copy of your program files. This means when you try to install the EvoScan and EcuFlash .xmls, the changes won’t take effect, instead the duplicate .xml will be used
    Try this! Uninstall EVOScan and ECUFlash and don’t reinstall them in C:\Program Files. Instead install to another directory created by you. For example C:\ECUPrograms\
    Added this to the first post!
  9. #419
    Dec 2011
    Iowa
    Greg, you are a BOSS! Thanks man!
  10. #420
    Aug 1998
    I might make the switch to EVOScan 2.7 for chrome V2. There seems to be a large demand for it for some reason.
