I'm a big DIY'er and already have a quality set of seals plus OEM gaskets so if I don't get it to seal up on the first shot I will try it again. I found a few different sources for the seals so I'm sure I can come up with what I need to get it to work. I'd rather upgrade the throttle body than go new but it all comes down to whether or not the rebuild works out. If not I may be shelling out the cash for a plenum and Q45 tb.![]()
Has any of the 91-95 guys used one of the EVO MAP adapters for DSM's? This seems like a nice easy solution for us.
2G/EVO MAP Sensor Adapter - JM Fabrications
9B+93-13.2@108
16G+E85...?
the cake is a lie
I was under the impression that it is what they use to run the OE EVO X map sensor since they do not have a spot for it either.
Example
Here is an example of the one you are thinking of I believe.
STM: INTAKE MANIFOLD SENSOR ADAPTER | 95-99 DSM | EVO VIII-IX
I know where to get a couple 98 sl ecu's I had to pay for the info so when I get home I'm going to post up the info for all to see lol its not a secret just numbers where to order. And greg thank you very much for rehosting that I was looking it over last night great work its a lot of info to take in.
it looked pretty clean when I had it off during the rebuild. thanks though
