Page 36 of 166 FirstFirst ... 2634353637384686136 ... LastLast
Results 351 to 360 of 1658
  1. #351
    I lack color... verified
    Aug 1998
    Quote Originally Posted by Patryn View Post
    I'm not sure if it has been answered before, but as far as the MAF replacements go, are there any measurements on diameter or size compared to our stock ones? Is there a MAF which is better suited for TD05 or larger turbos, than standard TD04 upgrades, as far as it pertains to 3S cars and flashtune?
    Well the EVO MAF came on a car with a TD05 turbo...
    Quote Originally Posted by iceorphen View Post
    So I just read through the entire thread, and I've got a few questions, forgive me if I overlooked something, it was a lot to read
    I'm going to pickup a 98sl ecu to flash, I know it doesn't support the BCS, I assume this would prevent me from logging boost via evoscan?
    Also, can someone point me in the direction of a 94>98/99 conversion harness?
    Im eager to get my dr700 car on the road
    Thanks in advance
    You can log boost with your ECU and EVOScan. Boost logging is done thru the MAP sensor pin.
  2. #352
    Keeping it real...
    Oct. 2006
    Reno, NV
    Hey Paul looks good. How well is it clamped on the flange though? Any gaps? Ill post up mine elsewhere in a bit.
  3. #353
    I tried that on my car and wasn't comfortable with how loose it was. I know it only sees vacuum but still...
    hmm, maybe my clamp is stronger. I could crank it down until plastic broke if I wanted.
  4. #354
    Place to pickup a harness:
    http://www.3sgto.org/f62/conversion-...-ecu-7442.html
    And yes you can still datalog boost on the 98SL ECU, even though you can't control boost.
  5. #355
    could one of you guys that are logging check something for me? The idle position switch in evoscan always reads 0, but I tested it with a multimeter and set it up correctly.
  6. #356
    Can you rehost the file I was trying to download it and test it out when I get my 98sl ecu in. My cable is on the way from blackstealth(Great guy helped me alot)
  7. #357
    LOVE YOU GREG< NO HOMO!
    My evo maf connector came in yesterday and I actually just cut the old connector off since mine was in really bad shape. It looks really clean this way. The car fired up right away like I'd never shut it off idleing a little rich around 13.5:1. After maybe 30 seconds it pulled up into around 15.5:1 and settled there. It may be a hair lean because right now there is no air filter, but it is probably also caused by a vacuum leak somewhere. The idle still hunts a bit, but not as bad as before, so I'm going to have to leak test and see what's going on. I also can screw the biss all the way in and still have about 1000 RPM idle speed, so something is up, I have the flash set for 850.
    I really want to thank you and Jeff for making this possible. It is amazing I can take an SL ECU and an evo maf and the car fires right up and runs without any piggyback adjustments on 550s.
    Please guys show some support, this is a Godsend to us.
  8. The Following User Says Thank You to Chris@Rvengeperformance For This Useful Post:
  9. #358
    One fix at a time verified
    Kansas
    I should have mine installed soon too. I'm currently chasing vacuum and boost leaks. The throttle body shaft leaks big time where I can't hear any other leaks in that area if there are some plus it starts immediately as soon as I put 1 psi in so I'm definitely getting my tb rebuilt. Thankfully I had been saving back a set of seals for awhile so all I have to do is install them. Once I have all the leaks fixed and the car runs decent I will probably swap in my 98 SL ECU. I'm anxious to see how it works. I should swap the ARC-2 out for awhile for the EVO MAF.
  10. #359
    Aug 1998
    Another very expensive but more than worth while investment for this setup is a brand new Mitsubishi Throttle Body. That alone will make your car run stock smooth....or at least a remaned one with new seals, IAC and FIAV.
  11. #360
    Keeping it real...
    Oct. 2006
    Reno, NV
    Sounds exactly like what happened to my 92 TT when the timing belt was installed improperly. The front bank, exhaust cam was off 2 cogs. Car ran good, but could never idle correctly. Just an idea.
