Page 19 of 166 FirstFirst ... 917181920212969119 ... LastLast
Results 181 to 190 of 1658
  1. #181
    Wilmington, NC
    Quote Originally Posted by Zybrainn View Post
    What were the exact values you changed in the ecuflash?
    First, all I changed was the
    MAF size: 357.5 g/s
    MAF adder: 140 units
    -for the evo maf (numbers provided by monochrome)
    Injector size: 554
    Injector latency: (first at just 14v, then I went through and provided proper latency voltage for 10-14v)
    10.03v=.915
    10.99v= .810
    12.01v= .675
    12.96v= .585
    13.99=.510
    I haven't messed with the idle drive much, and all of my peripheries in bit 2 are set at 1 except bit 12 which is 0. Do I need to change these values?
    Thanks for your help. I don't have stock injectors or MAF either (swapped over from an arc-2 setup), so I can't go back to stock to troubleshoot.
  2. #182
    Quote Originally Posted by 75blackray View Post
    MAF size: 357.5 g/s
    Injector size: 554
    10.03v=.915
    10.99v= .810
    12.01v= .675
    12.96v= .585
    13.99=.510
    I would update the peripheries first (does things like disabling rear o2's which your car does not have stock) and if that still doesn't work, I would look into the wiring. I ended up buying the wiring kit from blackstealth (awesome work btw) so can't help much there.
  3. #183
    Wilmington, NC
    I just updated the peripheries and bumped the idle, with still no change. I also bought my kit from blackstealth, but I will still check my wiring to make sure I didn't miss something. Nothing every works right the first time on my car... But I'm being patient with it this time around.
  4. #184
    I lack color... verified
    Aug 1998
    Sounds like you got a massive intake leak somewhere or you don't have the correct MAF. What number is stamped on top of it?
  5. #185
    www.chromedecu.org verified
    DFW
    I may have missed it but what year is your car? is it fedral or california? What ECU are you using? was it modified? And what are your periphs set at? and where are your O2s at in the exhaust system?
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  6. #186
    Is there an alternative site to download the files?
  7. #187
    SDSU Alumnus verified
    Nov 2006
    Chula Vista SD, CA
    Hiya, you have the MAS upgrade and RC 550cc injectors, correct? You can try these values as they worked from well over a year ago:
    11.72v//0.990ms
    14.06v//0.780ms
    ...then a/f goes way lean....The 02's don't seem to be cycling...
  8. #188
    DFW
    Also I just chromed my ECU yesterday and took my car for a spin. Idles great. Very cool to be able to datalog boost! I haven't done any tuning just basic file with Evo560s and stuff. The big maps look fun!
  9. #189
    Aug 1998
    Quote Originally Posted by Jesters Deadd View Post
    V2 will have so much more cool shit to play with! Just wait.
  10. #190
    Aug 1998
    Quote Originally Posted by Prizefighter View Post
    Try them now.
    I got the hardware to host my own link. If I get time this week, I'll have a (better) permanent host for these.
