I wire pin 67 on a switch button and it work fine
just wondering if its normal for the check engine light to randomly flash during 2step
im assuming that its flashing because the motor is knocking
I have a four button setup for my "extra" things. Im going to wire it into one of those.
1for exhaust cutout
1for 2step
1for my white led car show lights
1for something else
Sent from my DROID RAZR using Tapatalk 2
1991 VR4 - TD04-19THL, DR Stg3 heads, All forged lower end, Adj. Cam gears, Boost Exh. cutout, Walbro 341 HW'd, 720cc inj., AEM FPR, Hallman MBC,
Clone ECU and Chrome V2 - Tuning for 20-PSI on 91 Pump at the moment
y would u need a button for the 2 step
My log of Airflow Hz don't work, what wrong ?
LoadBitRaw00 and LoadBitRaw01 stay at 0,1 or 2 even at high load !
I use formul (LoadBitRaw00*255+LoadBitRaw01)* 6.29 / 64
I tried flashing chrome v2 to my car the other day and it errored out during the initial flash. After trying to flash again, I kept getting the following error message: "WARNING: failed to erase page at 0002C000". I could read the rom and test the flash just fine, just couldn't get the write function to work.
I tried searching but couldn't find much other than wrong processor names in the xml when this happens on people's evo's.
I have a battery tender hooked up to the battery so voltage shouldn't be a problem. I'm using Ecuflash 1.42.2595 and I also tried the 1.43 beta version. Any ideas anyone?
