Page 162 of 166 FirstFirst ... 62112152160161162163164 ... LastLast
Results 1,611 to 1,620 of 1658
  1. #1611
    iceorphen
    Guest
    if we deleted abs should what should we change the ISCV bump up to? leave it alone or zero it out?
  2. #1612
    I lack color... verified
    Aug 1998
    Leave it alone. With no ABS pump grounding the ABS signal pin the code will never reference that cell.
  3. #1613
    Oct 2010
    St Louis
    The omni sensors plug into the OBD2 map sensor harness but unfortunately they don't fit onto our plenums. Some minor grinding could be enough but I don't go for "make it fit" style set ups. Bob Melton has one on his 99 which he had to flip around 180 degrees and grind to make fit.
    Your best cost option is the GM 3 bar and mount it onto the firewall. Run a vac one to it from the nipple on the back side of the plenum.
    To wire it up, the easiest way is to buy the GM pigtail and wire it to the EGRT harness as that has the signal and ground. Most people tap the TPS for 5V power. The last thing you'll need is to make sure the EGRT signal pin goes into pin 92 of the flash ECU on your adaptor harness. I'm also fairly certain you can talk Brett into making you a GM harness plug with wires long enough to reach the ECU and pins to make it a simple install affair.
    On all my latest harnesses, there is a yellow pigtail which is Sensor 5v, and a green pigtail which is Sensor ground, besides the map sensor input pigtail. Also you should not use just any ground point for the map as a floating ground will skew the output.
    My standard map harness is three wires in a F6 high temp split woven loom for the 5v, ground, and signal...
    I have thought about offering the gm and mitsu plugs as an option....
    www.ClonedECU.com
    The home of the Original Clone and Clone2 ECU!
    More Plug n' Drive and less Plug n' Fail like the others!
    Remember, if it's not a Clone, it's just a copy!
    Get Chromed!
    Donate Now and receive a coupon code for the amount of your donation (up to $50.00 US) which you can apply at check out for a Clone2 ECU, Plug n’ Play Harness, or Clone2 Plug n’ Play Package!!
    1999 3000GT VR4
    Glacier Pearl White
    Yeah it's stock . . . trust me
    How To Contact Me:
    eMail: brett_farnam@yahoo.com
    US3S/3SGTO: 99 vr4
    3SI: bfarnam
  4. #1614
    Feb 2012
    Westbury, NY
    I'm in as well Greg........
    Tommy Williams
    Yes it's out. Shoot me a donation and I'll email it back.
    nonstopmix@gmail.com
  5. #1615
    Hopewell Junction, NY
    Got bored
    figured id post these not sure if there 100% right
    Omni 4Bar Map
    Volts....... PSI
    0.............-14.5
    1..............-2.415
    2...............9.673
    3.............21.759
    4.............33.846
    4.8..........43.515
  6. #1616
    Aug 1998
    Chrome V2 is ready for download!!!
    http://www.upstageproductionsinc.org...et_chrome.aspx
    Chrome manual will be finished soon and this thread will be locked!
    Special thanks to Brett again for hosting but more importantly all the setup time in coding the simple donate and download setup!!!
  7. The Following 10 Users Say Thank You to Greg E For This Useful Post:
  8. #1617
    Awesome Greg! Is there anything I can play with with the car in the garage?
  9. #1618
    Aug 1998
    Fuel pump on Clutch is fun to play with. I procrastinated taking pictures of how to wire up the clutch switch too long. It snowed here today....
  10. #1619
    N8RZ VR4 - 19THL VR4 supporter
    Jan 2011
    Brentwood, CA
    So is that write-up in the new manual? I'm going to start messing with my car tomorrow. Putting in the montero maf and 720's
    Sent from my DROID RAZR using Tapatalk 2
    1991 VR4 - TD04-19THL, DR Stg3 heads, All forged lower end, Adj. Cam gears, Boost Exh. cutout, Walbro 341 HW'd, 720cc inj., AEM FPR, Hallman MBC,
    Clone ECU and Chrome V2 - Tuning for 20-PSI on 91 Pump at the moment
  11. #1620
    Aug 1998
    Quote Originally Posted by Nater3kgtVR4 View Post
    It's very simple. Cut the wire for pin 67 of your ECU adapter harness. That pin should be populated and do not tap it! Now extend the ECU side of the wire you cut to reach all the way over to the cruise control power kill switch (easier one to access) or the starter interrupt switch. This involves crawling under your dash and tapping one of the two wires (do not cut it). I can't remember what color wire it is you want to tap but it's the side that does NOT go to chassy ground.
    Again, I'm sure Brett can be sweet talked into including a wire for this with this ecu adapters.
