Page 16 of 166 FirstFirst ... 614151617182666116 ... LastLast
Results 151 to 160 of 1658
  1. #151
    Aug 2011
    For the last time, the SL has the same parts.
  2. The Following User Says Thank You to Jeff V. For This Useful Post:
  3. #152
    I lack color... verified
    Aug 1998
    Quote Originally Posted by Jeff V. View Post
  4. #153
    Damn... They've gone up in price over the last few years.
    How much of a demand is there for these? If we have at least 5 people I will start a group buy.
    What kind of price are we looking at for the group buy?
    I would love to have one, though the main reason is for logging and getting my stock boost gauge to work since I am using the black stealth boost controller.
    I purchased a 99 SL ECU so I do not expect the stock boost gauge to work. On the other hand, I do have a GM 3 bar map sensor so I'm wondering if the ECU can be flashed to have the stock boost gauge work? I should be installing a flashed ECU to run 15g turbo's on 560cc injectors within a few weeks.
  6. #155
    Aug 1998
    The hardware isn't installed on the SL ECU to operate the boost gauge nor the stock BCS. You can install the sensor to read boost thru pin 92 though as it does have the MAP sensor input.
  7. #156
    Hopewell Junction, NY
    my injector scale only got up to 621cc how do i go higher?
    Kx
  8. #157
    July 2005
    Arkansas
    Quote Originally Posted by Kx1984 View Post
    Kx
    You hit = and type in whatever you want... I just tried 1000 and it worked just fine...
  9. #158
    ok i missed that wasnt sure on if i should mess with that lol
  10. #159
    Just sent you some money as I just took the car for its first Chromed drive without CEL The tune is almost perfect!!!
    CAR: 1994 JDM GTO
    MODS
    99 SL ECU
    OP 2.0 cable
    BlackStealth 99 ECU Convertion cable
    LCD Boost Controller
    Hotwire kit
    evoscan
    LC-1 wideband
    560CC EVO injectors
    walbro 255
    3SX Executionors
    stock maf
    lots of others, but that is the main ecu related stuff. Will be getting a exhaust and then on the dyno to see what it can make.
    I used the narrowband output on the LC-1 as a input for BOTH o2 sensors. Trim are great
    Glen
  11. The Following User Says Thank You to jazz9 For This Useful Post:
  12. #160
    Oct 2010
    St Louis
    @jeff... Talked with Von, instead of a knock box we are going too read raw knock voltage at the knock sensor (o-scope) for calibration. This will isolate the ecu hardware to determine what changes if any the ecu hardware makes on the interpretation of the sensor and the resultant tune. The hope is to "qualify" or "certify" certain ecus.
