Ok, so what pins I need to inverse on the harness ?
You can show my log here http://mornantautosport.free.fr/3000...s/log0001.xlsx and show the AFR >18 and >16 in cruise !
Greg, he actually has a European Spec 3000GT! Not a GTO. LOL Oh and France is a right hand drive country like us.
Greg, I pre-flashed his ECU with the London code. This is 1998/1999 Code base with the peripheries turned off for the lack of emission gear.
An email was sent to Walter showing how to verify the pins. They should be correct, as they were corrected a long time ago. BUT, your car may be different due to the fact that it is a EUR 3000GT.
www.ClonedECU.com
Get Chromed!
1999 3000GT VR4
Glacier Pearl White
How To Contact Me:
eMail: brett_farnam@yahoo.com
US3S/3SGTO: 99 vr4
3SI: bfarnam
it is very nice to think of me guys
I tested O2 sensors tomorrow, because it's late here
So do you think a pin 75 & 76 inverse enough of get a correct AFR ?
installed and flashed my ecu last night, realized i had lower turbo hose off so it was running like shit.. fixed that and im idling at 700-750.
Dr700s
RC 660 injectors
aem fpr (reading@ 60psi idle right now XD)
Im using Aaron's bit settings, no CEL yet, havent taken it out since this is a motor with 0 miles :P after everything is adjusted and i do an oil change ill drive this bitch around =)
Do NOT USE Aarons periphery 0 settings!! Leave that whole section alone!
First verify the pins via the email I sent you.
Then please tell me:
Do you have 1 or 2 oxygen sensors?
Do the oxygen sensors go to the correct pins in the connector from the email I sent you?
Are you running the "Chrome" ROM?
What version of "Chrome" ROM?
Vérifiez tout d'abord les broches via le courriel que j'ai envoyé.
Alors s'il vous plaît me dire:
Avez-vous 1 ou 2 capteurs d'oxygène?
Ne les capteurs d'oxygène aller aux broches appropriées du connecteur de l'email que j'ai envoyé?
Utilisez-vous la "Chrome" ROM?
Quelle version de "Chrome" ROM?
e85 wally 400, I know the pressure is absurdly high. This is a new motor literally 1st start. Tomorrow after I change the oil and start it up again ill adjust my fpr and begin to work on getting the trims just right.
Ill also put periph0 back to how it was, there is soo much info in this thread its hard to keep up with all the changes
Havent driven it in almost a year I cant wait to get it going
