Page 146 of 166 FirstFirst ... 4696136144145146147148156 ... LastLast
Results 1,451 to 1,460 of 1658
  1. #1451
    I lack color... verified
    Aug 1998
    Quote Originally Posted by 3000gttom View Post
    have you guys tried any alternate ignition systems
    with the ability to change dwell times we could potentially use COP and get power gains without an amplifier, evo guys do it
    we could maybe use other coil packs with bigger coils, or even make more power out of the stock coils
    im just kinda wandering if anyone has looked into this, i didn't find anything on changing ignitions with flash ecu when i searched
    It's on the list of things for me to do.... Coil on plug like Matt Jannush had on his car was one thing I plan on doing with my 98 build.
  2. #1452
    www.chromedecu.org verified
    DFW
    Hmmm I have some old sport bike COPs laying around....
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  3. #1453
    Aug 1998
    Quote Originally Posted by Jesters Deadd View Post
    A plug and play kit are what we need.
  4. #1454
    August 2010
    Chicago
    Ive got 300M coils just waiting to be installed too..
  5. #1455
    Oct 2010
    Oshkosh,WI
    I'm thinking of trying a COP system too, but that will have to wait until spring.
    I don't know if there would be any benefit in changing the dwell on stock coils, if someone was using an aftermarket coil pack (MSD, Accel, etc.) it may increase spark output. I also have no real data to base that off. I thought about playing with it, but didn't feel like burning up my coils.
  6. #1456
    Jan 2012
    Pittsburgh
    yea dwell(charging) time is pretty important. its the reason why COP makes less power than stock because the stock dwell is set to charge one coil not two. but increasing time puts load on the ptu and it can burn up
    theres a lot too it that i really dont fully understand but i feel like still having a coil pack is the best option because the stock ecu cant do sequential ignition but i think we could upgrade to different coils
  7. #1457
    August 2010
    Chicago
    I enabled bit 2 of periphery 0, now the trims are cycling like they should....BUT the car still has startup problems. 7 times out of 10 I need to unplug the injector resistor pack to start the car. It seems like its more of an issue on hot starts than cold starts. I have 2 sets of latency values for the same injector (delphi 1000cc/pte1000cc). I'm gonna trying switching the values to see if it helps. Also going to monitor fuel trims.
  8. #1458
    Aug 1998
    No the problem is you need to edit the startup tables which aren't visible in V1. Have you read my Disasembly thread about the Start up routine? I think it's still on the first page of the general section.
    Tell you what. Email me the tune currently flashed to your car and I'll edit the start up tables for you and send it back.
    Nonstopmix@gmail.com
  9. #1459
    August 2010
    Chicago
    Hey thanks a bunch...I really appreciate it. Even if the tables were visible I don't think I would know what to do....why do they need to be modified anyways? Aside from the fact that I'm running significantly larger injectors??
    All the flooding has resulted in a random multiple misfire being thrown...now I'll have to change my plugs too...
  10. #1460
    Aug 1998
    Quote Originally Posted by NOMIEZVR4 View Post
    That's exactly why. Read the thread.
    http://www.3sgto.org/f2/disassembly-...bles-8068.html
