all of that info is in this thread. The injector setup is simple:
Put in approximate latencies and injector size. Car *should* be drive able if you put half way sane numbers in. Drive it around town for 10-15 minutes. Check the fuel trims.
The latencies have about twice the effect on the low trim as the med trim because the injector pulse width is so low at idle. So, for example.
Low Trim -10%
Med Trim - 5%
Then you need to REMOVE some injector latency so the ecu will open the injectors for a shorter period of time. Log it again until low and med are close to the same. For example:
Low Trim -5%
Med Trim - 4%
Now ADD 5% to your injector size to REMOVE 5% fuel.
That's pretty much it. Once the trims are good do some wastegate pulls and see if it goes lean. If the afr is safe you can then start tweaking the fuel map if you want.
