Page 13 of 166 FirstFirst ... 311121314152363113 ... LastLast
Results 121 to 130 of 1658
  1. #121
    SDSU Alumnus verified
    Nov 2006
    Chula Vista SD, CA
    Also, out of curiosity, what is your reason for leaving the scaling table alone? I did all three for an VIII MAS as you probably recall.
  2. #122
    I lack color... verified
    Aug 1998
    Quote Originally Posted by bboyalan View Post
    The scaling table you used is setup for an EVO intake/innercooler/piping. When I used the EVO values on my stock 99, the trims got a bit out of whack.
    Think of the scaling table as a HZ to airflow conversion table. Raising/Lowering the values on the right side of the table will tell the ECU to add/subtract more IDC for that particular HZ value. Use the fuel trims as a guide to fine tuning the scaling table if you have upgraded intake/innercooler/piping and you can't get the trims between +/-5%.
  3. The Following User Says Thank You to Greg E For This Useful Post:
  4. #123
    Nov 2006
    Chula Vista SD, CA
    Mm interestingly put - thanks! We must have gotten "lucky" then haha. I will revisit that since things have changed a bit.
  5. #124
    www.chromedecu.org verified
    DFW
    This is good to know. I was wondering this.
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  6. #125
    I am looking to fit the EVO 8 MAF to my setup and was just checking what people had to do with the conversion? wiring changes ?
  7. #126
    Keeping it real...
    Oct. 2006
    Reno, NV
    Lol, seems like you all have made yours at work.
  8. #127
    Aug 1998
    Quote Originally Posted by ChargerX3 View Post
    I handed a few out at the national gathering. I also have a few wiring harness pieces left to make a plug and play adapter... :-)
  9. #128
    Keeping it real...
    Oct. 2006
    Reno, NV
    Hand out a few my way...lol. The harness is the easy part.
  10. #129
    Wilmington, NC
    "Now open up ECUFlash, go to C:\Program Files (x86)\OpenECU\EcuFlash\Chromed ECU v1.0 and open 23861006.bin. This file is a stock tune. "
    When I try to open the binary file in this step i get an "Unknown ROM image" popup with a message saying, "EcuFlash could not recognize this ROM image using any of the current definitions. You can choose one of the following options: Abort using this ROM image or Use wizard to create a new definition (NOT RECOMMENDED!!!- FOR DEVELOPERS ONLY)
    What did I do wrong?
  11. #130
    it sounds like you skipped this step:
    The 3000GT folder contains the definition file. Inside the folder is the 23861006 XML file. Extract the 3000GT folder to:
    C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi
  12. The Following User Says Thank You to Chris@Rvengeperformance For This Useful Post:
