Turbosmart makes a dual port valve that a lot of people are liking, I've never ran an open atmosphere personally.
98-99 solenoids only? Looks like they made 5 different ones for the turbo models.
Edit, maybe I should say they made 5 different part numbers, not necessarily different solenoids.
92 3000GT VR4
Matt
Be prepared for used EGR solenoids to fail. Mine did!
Ok so I have the
Adapter harness
98 SL ecu
And the open port 2.0
Where do I get the most current version of the file to flash
Running in a 93 vr4
Sorry If I missed it
Kx
oh ok lol duh ill try and read thought it theres alot
one quick question im fine running the 98 sl ecu correct? anything i should know?
kx
Minor problem I'm having happens once every 30 mins or so. At idle afr will slowly climb up to ~18 and splutter etc. The slightest touch of the throttle will bring it back to the 14s. Sometimes happens while cruising and will lean out with light throttle I can push through to open loop and its fine. It takes about 10 seconds to recover when cruising. Any thoughts? Like I said it's not a huge issue and I havent logged to capture the problem yet.
I have a GM solenoid sitting on my bench waiting for me to test it. I just have not had the time. I am doing my two weeks US Army training right now so my time is VERY limited. I am a prime candidate since I have stock ECU boost control and have all my vacumn lines . . . basically it's stock except that I have 15Gs . . . so I over run the stock BCS very easily.
www.ClonedECU.com
The home of the Original Clone and Clone2 ECU!
More Plug n' Drive and less Plug n' Fail like the others!
Remember, if it's not a Clone, it's just a copy!
Get Chromed!
Donate Now and receive a coupon code for the amount of your donation (up to $50.00 US) which you can apply at check out for a Clone2 ECU, Plug n’ Play Harness, or Clone2 Plug n’ Play Package!!
1999 3000GT VR4
Glacier Pearl White
Yeah it's stock . . . trust me
How To Contact Me:
eMail: brett_farnam@yahoo.com
US3S/3SGTO: 99 vr4
3SI: bfarnam
