Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 63
Thread: arc2 and e85
  1. #31
    One fix at a time verified
    Kansas
    Quote Originally Posted by keo92stealth View Post
    alright sounds good. hopefully she will be ready by friday. man, im so freaking excited lol. no hopefully i can get it to run correctly. ill try them settings you gave me awhile back. +1 -7 -7 +2. now, if its to rich at idle, i back of on the low and but it and 0 or go into negatives? i now the mid stays -7 no matter what. now when the car is warm, and i give it gas and she stumbles, back off on the high and accel? or only 1 knob at a time?
    The ACCEL is mainly used for idle. LOW does affect it but it's only for cruising and small throttle inputs. If you're running too rich cruising and have to make a big adjustment you will have to readjust the ACCEL. Most cars are usually happy around +1 to +3 on the ACCEL. For some reason my car is higher than that. If I go any lower it will stall out. I think it's contributed to some vacuum and or boost leaks I need to check for since my boost controller is overboosting plus the hotwired Aeromotive Stealth pump I'm sure is overrunning my stock fpr.
    If it's rich at idle increase it one click on the ACCEL and vise versa for if it's lean. You don't want to mess with it too much when the car is warming up because it will have to be changed again once it's warm. Just change the settings enough that the car will idle without stalling and an AFR that isn't rich say 10-11:1. You will get fuel in your oil and will need to change it asap if it idles rich. Once you have the idle at warm dialed in close to 14.7:1 you then want to focus on cruising. Go tool around in 2nd or 3rd around 2k-2500 rpms and adjust the AFR to achieve close to 14.7:1. You can adjust this later but get it close for now. From there you then want to datalog and make some WOT runs from 2500-redline. If it starts running too lean or you get knock let off the throttle immediately. Check to see why the engine knocked. If it was too lean add one click to the HIGH knob. If it was too rich pegged at 10:1 AFR subract one click. Rinse and repeat until you get a 11.5:1 AFR WOT or a little richer if you'd like some more safety margin. I would not recommend trying to soley tune it by watching your AFR while going WOT because the wideband might not be responding fast enough or you just can't get a good enough reading plus it's dangerous not focusing on the road. Review your logs and it will be much more helpful. You're better off adjusting one knob at a time focusing on idle, cruise, and then WOT in that order. Doing everything at once will leave you chasing your tail the whole time. The above AFRs are for pump not E85 FYI.
  2. #32
    Jan 2011
    az
    ok so in other words, the low and accel is for idle and just your basic driving, mid is always -7 and the high is for wot? so if you have to adjust the accel then you have to adjust the low? sorry for the noob questions!
  3. #33
    Basically put Accel on zero and tune your low, if you can't get it where you want it with the low only than set the low knob a little lean of what you want and add accel.
  4. #34
    Jan 2011
    az
    ok another noob question. lean is the negative side correct?
  5. #35
    Right is rich, left is lean.
  6. #36
    Kansas
    If you get your base settings close you usually won't have to go back and retune the ACCEL after you mess with the LOW. I'm talking about a huge change like 4 or 5 clicks. That will cause you to have to retune some of the other settings if it's that far off. Think of ACCEL as the idle enrichment. Turning clockwise richens on any of the knobs and turning counter-clockwise leans out. It's more than just right being 0 to +20% and left being 0 to -20% fuel correction. You don't have to be on the negative side to run lean. Say you're at +6 on HIGH for example's sake. +3 may make you super lean WOT such as at 12.5:1 AFR which is no good for WOT. So for the sake of simple argument just remember to turn it right to richen and turn it left to lean out. Let us know how it goes and if you can't get the car to run right. It's very simple to setup. Make sure that you solder the yellow wire coming out of the ARC-2 box to the red wire. They both go to +12V switched power!!! Very important or else you won't get the tune right ever.
  7. #37
    Jan 2011
    az
    ok got you i think. yea, i had splitsecond bench test the unit a while back and they tested it as the r5 version so when i did install it , i did put both those wires red and yellow to 12v power. the only one i didnt do as the instructions said was the black wire and that was a ground for the tps? my engine harness might have been chopped our something beacause after following that pin after about 8 inches, the wire was cut so i just put the ground to the chassis. i hope i have no issues with that situation. unless that ground absolutely has to be wired into that pin or whatever.
    oh yea, and the maf is in blowthru thanks to turbosincebirth.
    ok so again, start at +1 -7 -7 +2? mid stays the same so if the idle is to rich or lean, increase or decrease the accel or low? and if its to lean or rich at wot, increase or decrease the high?
  8. #38
    Kansas
    I have mine hooked up to the ECU ground. I wouldn't trust it hooked up to the TPS or any other sensors in the engine bay due to all the issues you can have with brittle old wiring like you said. I always run MAP and IAT sensor wiring all the way back to the computer. The ground you're talking about is pin #72 ECU ground for the TPS, 02, IAT, etc sensors not pin #71 chassis ground. That's for a 1st gen.
  9. #39
    First, read this.
    Stealth 316 - ARC2 Tuning tips
  10. #40
    Jan 2011
    az
    yes, that is the correct pin. i just couldnt place it. well thanks for all the help. hopefully, i can try to start her up by friday and get her back on the road. ill definately keep this updated. and ill start off with them settings and go from there. thanks.
