So you're saying the body itself is structural? Ahh, I see what you're describing. The actual design method you're referring to is called Monocoque. Yes, the rear hatch is monocoque designed as it's dependant on sheets for its structural rigidity. I'm actually pulling all the sheets to convert from monocoque to spaceframe. Spaceframe is much lighter and relys soley on triangulation to balance the tension and compression of the frame. Essentially, thats what principle caging a body in tubular material is based on.
My main concerns in the rear chassi are the forces exerted on the suspension mounts, impact zones, and any forces that may come from driveline torque. Once I clean up all the sheet metal I'll triangulate the loads back to the main frame and suspension towers and have much more structural rigidity vs. the OEM monocoque design. As for the driveline torqu that causes twist, our cars are AWD so the force is already proportioned so I'm really no to concerned about it. My thinking is The lighter I get the chassi, lower I move the weight, and smaller I make the CG radius, the faster and stronger the car will be?
, and a few other factors. I'll be forced into making that decision soon enough though.
