Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: TPS Problem
    Cazenovia, NY
    I wasn't disagreeing with you, your thinking is sound, I was just suggesting he confirm 5v (100%) on the signal wire, rather than assume it's there from scan data.
    I would agree with that statement as well. If the 5V is coming directly out of the source (the TPS), then at least you know the problem traces back on the entire line.
    What diagram? I don't think I've seen that one... The idle switch is how the ECU determines closed throttle.
    From the service manual.
    I suppose they may not have included it in that.
    The evos are set up the same too
    St. Charles, IL USA
    Sensor ground is the first thing I'd check. If it fails the TPS output floats to 5v.
    Cazenovia, NY
    Quote Originally Posted by steve View Post
    Exactly
    BUS LENGTHS
    penn, PA
    Does anyone know if this was resolved?
