Results 1 to 10 of 16
Thread: Need help please
    Dec 2011
    jasper alabama
    Need help please
    Ok I bought a 95 vr4 for 1200 guy said it needed new linkage so I fixed that now it will go into any gear but 1 and 2 any ideas thanks
    www.chromedecu.org verified
    DFW
    linkage adjustment?
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
    Dec 2011
    jasper alabama
    How we adjusted it yesterday and found 3-6 and reversse but cant seem to find 1 and 2
    I'm Kind Of A Big Deal
    You put 6spd cables in it?
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    Any hoses, etc in the way? Shift through the gears, and have someone watch the linkage, and see if you're bumping into anything in the engine bay.
    Dec 2011
    jasper alabama
    I put 6 speed cables in and the weight is cut off to clear the intercooler pipe but it bumping the radiator hose
    Then you need a 6spd radiator hose. They are different between 5 and 6spd, someone probably installed a 5spd lower rad hose.
    Dallas TX
    Or the radiator hose is turned the wrong way. It still connects when turned the other way, but then it can get in the way of the linkage.
    Dec 2011
    jasper alabama
    Ill try it when I get home thanks ill let u know how it turns out
    Dec 2011
    jasper alabama
    Ok hose not the prob it just wont go all the way in and some timess when I put in in neutral it sstill in gear
