Finally got a datalogger about a week ago, and I have been using it like crazy. Everything on my car checks out but my o2 sensor. Datalogger shows 4.98v non stop for my o2. So I assume its bad.
Here's my side effects.
MPG.....not too bad, I think it may be just how I drive. Its unconsistant with 18-25mpg
Does not like to move very far when its cold
Lopey idle....very lopey....it sounds very sexy and a lot of people ask if I have aftermarket cams.
I tell them I'm not sure.... motor was replaced. And the cams in it are not originally from that motor that is all I know.
Idle is pretty steady at 850 rpms. The lopey idle is very consistant. Doesn't feel like a miss...big difference between the lopeyness and when I kill a cylinder or 2 with the datalogger.
Car drives fine. Drive it everyday, pulls good when I want it too and cruises smoothly.
Car has had this lopey idle since the day I fired it up. No cel for o2. Maybe I just have cams. I'm going to do waterpump soon, I plan to measure the cams out and that will settle it. I installed wideband to hook up the wbo2 in place of the factory and the wbo2 is also shot. Going to order a new one.
